Ear-Relevant
May 22, 2017Aspirant
ReadyNAS Pro rebooting and resyncing, with file copy hangups and other issues
I have been using a ReadyNAS Pro RNDP6350-100NAS for many years as a home music server (Logitech Media Server) and backup for my PC and data files. Firmware is 4.2.30. It has not been 100% st...
Ear-Relevant
May 27, 2017Aspirant
mdgm,
Thanks for your prompt diagnosis.
Earlier, memory testing passed 4 rounds with no errors. I also unseated and re-seated the cards in their slots.
That's a lot of work to test 6 disks, especially given the strong possibility of CPU/Motherboard issues.
Manufacturers replace models often, and previous models become hard to get. Also, with the discontinued models that are still available for purchase, sometimes you think you are buying a new disk, but the vendor is selling you a refurbished one. Sigh.
Over the life of this NAS, I have gone from 1tb -> 2tb -> 4tb drives. I began to mix drive models and sizes soon after acquiring the NAS. It was the most practical way to go forward as drives failed, prices fell for larger drives, and I needed a larger volume. Maybe not ideal, but the NAS seemed to work OK until about a year ago.
When the capacity first reached ~10% remaining free space, it started having problems with file copy operations about the same time. I deleted and/or off-loaded enough files to create ~20% free space. Then, the NAS began running fast and smooth, without hangups. This could be a coincidence, but it seemed a cause & effect at the time.
I will gve this thread a few more days.
Otherwise, I think my solution is going to be:
- Acquire a new NAS with 4 x 4tb identical drives.
- Restore from existing the NAS if possible because it seems stable for read operations of any size, just not write operations.
Btw, what does this say about the current problem(s)?
- If the existing NAS is not stable enough for this task, I have a full backup across 3 USB drives, and will use a fan to keep them cool during the restore to a new NAS.
- Then, I will start fresh with this ReadyNAS, using only the 2 x 4tb drives. If it seems to operate reliably again, I will add two more identical 4tb drives to it, providing a mirror backup to the primary, new NAS.
- The existing USB drives will be kept offsite and periodically updated once a month or so. I should already be doing this!
Questions:
1.) Should I (can I?) connect the two NAS units with an eSata cable for fastest transfer?
2.) Should I (can I?) I run OS6 on the ReadyNAS Pro?
Thanks again,
Ear-Relevant
Sandshark
May 27, 2017Sensei
The Pro6 doesn't have eSATA, but you couldn't connect them that way, anyway. Neither can you via USB.
Yes, the Pro6 can run OS6. If you are going to start fresh, moving to OS6 is an excellenmt part of the plan. Not only will you get a more up to date system on the Pro, you'll have two NASes with the same OS (assuming your replacement NAS will be a Netgear).
- Ear-RelevantMay 27, 2017Aspirant
Sandshark,
Thanks for clarifying about eSata and USB for between-NAS file copy.
I'll use mirror software to manage the transfer. This is gonna take a long time.
I am glad to be able to use the new OS6 on my ReadyNAS Pioneer Pro. Good News.
At this point, I am likely to switch to the Synology DS1517+. It seems a better value than current Netgear offerings, and the OS looks to be more user friendly. The less capable Netgar RN316 isn't much less expensive. With today's larger drives, five vs. six drive bays is enough for me. I hope this admission doesn't get me tarred & feathered on this forum! (;->)
After all, I want to get a more use out of the ReadyNAS Pro, and may need to ask additional questions.
Cheers,
Ear-Relevant
- mdgm-ntgrMay 27, 2017NETGEAR Employee Retired
The RN426 and RN428 our new models with a quad-core Atom CPU. Our RN426 and RN426 are using a newer CPU (C3000) than the CPU used in the competitor model you mentioned.
Your Pro could have a bad disk, failing PSU, bad RAM, some other hardware issue.
Considering the age of your unit it's not that surprising that some hardware is failing.In any case like any PC hardware can fail at any time.
- SandsharkMay 27, 2017Sensei
You may want to consider upgrading the processor on your Pioneer Pro. The Pentium 1.8GHz E2160 in it is a bit slow, and replacement Core2 processors are quite cheap these days. Mine are running a 2.93GHz Core2 E7500, which currently sells on eBay for about $5. Of course, if it's just as a backup system, it may not make too much of a difference.
If you do decide to upgrade the processor, make sure your BIOS is the latest. The fastest of the compatible CPU's need it and it's a lot easier to update while you are on OS4.2.x than on OS6.
Mentioning the competition, even that you own or may purchase one, is not a capital offense. Just don't advocate it.
mdgm,
I will give the Netgear RN426 a fair comparison with the Synology DS1517+ before making a purchase.
Yes, nothing lasts forever. As I like to say, "Getting Old Sucks!"
I need a new set of ears & eyes, a right hip, left elbow, and among many other things, my gray matter isn't as flexible as it once was.
Oh, well, that's life!
Thanks,
Ear-Relevant
Sandshark,
That's interesting about the inexpensive processor upgrade, also considering that the CPU might be what's causing the current trouble. Thanks for the tip!
I have favorites, but I try to not be a fanboy with any consumer products. I'm just trying to choose the best product for my needs in a crowded market. It is much more complex with something like an NAS, network speeds, backup strategies, etc. Phew!
On the topic of perfectionism and consumer choice, I often recommend a great book: The Paradox of Choice: Why More Is Less, by Barry Schwartz.
Peace,
Ear-Relevant
