OldNasMan
Mar 08, 2026Aspirant
ReadyNAS Pro Stuck at Booting…
I’m trying to resurrect my ReadyNAS Pro and it’s stuck at Booting… It will complete the FS checks, but can’t get past Booting…. I’ve attempted an OS Reinstall and a USB Recovery, but the USB ...
Mar 08, 2026Guru - Experienced User
OldNasMan wrote:My USB Recovery was the latest 4.23.
Latest would be 4.2.31.
Likely USB recovery was not needed.
Are you able to access Frontview?
You need to use a browser that will connect with TLS 1.1. You can use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
OldNasMan
Thanks for the reply.
Progress has been made. I took a single good disc and did a Factory Default on it and ran it through all six slots. 100% pass.
I then reinstalled the 5 original discs, in their original positions, and inserted the newly formatted disc in bay #5, it then detected a bad #6 drive. Evidently, with bay #5 empty and a bad #6, the boot sequence failed.
Unfortunately, 2 bad discs looks to equate to a total loss of everything. Is there anything that I’m missing to be able to retrieve anything off of the 4 good drives? If it makes any difference, the disc sizes are 4T, 1.5T, 1.5T, 1.5T, 0.5T and 0.5T. It was both 500G discs that died. Sure wish I had the money back then to keep all discs the same.
- StephenBMar 09, 2026Guru - Experienced User
RAID-5 only has single redundancy, so getting anything back would be challenging.
You could try RAID recovery software that supports ext. You'd need a way to connect all the working disks to a PC. Imaging them to one larger disk is one option.
