Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
Feb 09, 2013Guru - Experienced User
Could be a memory failure, or some other chassis problem. You should start an on-line support request (support.netgear.com), I suspect you will need to RMA the unit.
