Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
mdgm-ntgr
Feb 09, 2013NETGEAR Employee Retired
There is a VGA header on the motherboard. There is an obvious spot for a VGA port on the back of the unit but no header cable connected to it. I should have made that more clear. If you connect to that header you may see why it's failing to boot.
See e.g. http://www.readynas.com/forum/viewtopic.php?p=223230#p223230
Before you start replacing hardware that may be fine, check to see if you can get a better indication of what the problem is.
