Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
Hitman202
Feb 10, 2013Tutor
Ok, I see the Vga port on the back and as You stated, no cable connected to it.
But where is the Vga header on the mainboard?
All I see is a lot of pins, does this require a special cable?
I´ve allready purchased a new Cpu and Ram, waiting for them to arrive.
They were not that costly, so thinking I might as well try and replace them to see what happens??
