Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
mdgm-ntgr
Feb 10, 2013NETGEAR Employee Retired
You don't see the text VGA, RGB or something similar near the header port. Yes, the header port would be pins of some sort. You'd need an adapter.
Out of replacing CPU and RAM if you must try it replace the RAM first and see what happens. You would find having a VGA display useful of you try this.
