Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
Hitman202
Feb 10, 2013Tutor
Ok , I will try and replace the Ram and Cpu when the new parts arrive.
If that doesn´t work I will try the VGA bootup option.
Wont be here until wednesday (parts), so untill then I leave it as it is..
Many thanks for the advise;-)
Will follow up on this thread later on, hoping it could help others in the same situation...
