Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
mdgm-ntgr
Feb 12, 2013NETGEAR Employee Retired
You might find one on certain old graphics cards. You need to check the Pins on the motherboard and use one that matches.
