Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
mdgm-ntgr
Feb 13, 2013NETGEAR Employee Retired
Hitman202 wrote:
Could this be it??
That disk 5 was the fault?
Probably.
A good step in troubleshooting an issue like this would be to hook the disks up to a SATA port in a PC one at a time and check them.
Hitman202 wrote: I recieved the new Cpu today, didn´t make any difference.
though if it's a faster one than an old one you may see a performance benefit, so it was probably still worth installing it.
