Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
Hitman202
Feb 13, 2013Tutor
It´s the same Cpu that was in the Nas from the start (Intel E2160 Dual Core 1.8ghz)
Right now I´m backing up all the important data on the Nas to other drives.
This takes a while so I want to get this done with first.
Next step is to re-insert disk 1.
A bit hesitant, the unit has been "dead" for well over a week and all of a sudden working.
So a bit afraid that when I turn it off and put in disk 1 it will revert to the nonworking status.
