Hitman202
Feb 07, 2013Tutor
Readynas Pro stuck on boot
I have a Readynas Pro that is refusing to boot. When pressing the power butten the unit comes on, but goes no further than the Readynas logo on the display. Disks are spinning up and fans are runnin...
mdgm-ntgr
Feb 13, 2013NETGEAR Employee Retired
Yes, finish backing up your data first.
Put disk 1 back in while the NAS is on. If the disk is good it should be wiped and added to your array
