herbg
May 11, 2014Tutor
ReadyNAS Pro to RN516 Upgrade
I'm about to buy a RN516 with 6 Seagate 4TB 3.5" SATA3 64MB Cache OEM Hard Drive (ST4000VN000) that I will install myself. I currently keep all my media data on a ReadyNAS Pro 6350.
I intend to use the RN516 as my new media server with the ReadyNAS Pro as my backup (until I run out of space).
A few questions before I start the project:
1) Any tips on the best way to setup the diskless RN516 with the 6 new 4TB drives? Should I start expanding with 1 drive or several installed at once?
2) Once the 516 is setup, I have 8TB of data to move to the RN516. Is there a faster way than setting up a RSync backup from the PRO to the RN516 through the network?
Thanks for your help!
No, you shouldn't.herbg wrote: Firmware: 4.2.26 for ReadyNAS Pro and 6.1.9 on the RN516.
If I add the PATH to the DESTINATION, I'll end up with a "Photos" folder embedded into the "Photos" folder of the ReadyNAS Pro - won't I? - herbgTutorUnfortunately, that's exactly what happened.
Since I added the Destination into the path, I now have an embedded "Photos" folder - populated by duplicate files - in the ReadyNAS Pro "Photos" share.
The backup should be doing an incremental backup to the existing "Photos", "Movies", "Music", "Documents", and "Backup" shares on the ReadyNAS Pro with the originals from the RN516.
But that's not what's happening. I'm getting imbedded "Photos", etc folders in each of the shares on the ReadyNAS Pro with duplicated files.
I don't understand what's wrong. - StephenBGuru - Experienced UserI am backing up in the other direction (running the job on the RN102, with a remote source and a local destination). Path is specified on the local source.
Are you running a 6.1.9 beta? There was a beta release that had the duplicate folder issue, but that was quickly backed out. - herbgTutorYes, I was running the backups the other way for months too with no problems.
I don't think I'm running a beta version. There is no indication that it is a beta. How do I tell? - mdgm-ntgrNETGEAR Employee RetiredDownload the logs and let us know the contents of initrd.log and os_version.log
- herbgTutorHere is the log for initrd.log:
[2014/05/26 15:58:16] Factory default initiated due to new disks (no RAID, no partitions)!
[2014/05/26 15:58:40] Defaulting to X-RAID2 mode, RAID level 5
[2014/05/26 15:58:46] Factory default initiated on ReadyNASOS 6.0.8.
[2014/05/26 17:18:00] Updated from ReadyNASOS 6.0.8 (1371611904) to 6.1.8 (1398980083).
[2014/09/18 18:13:30] Updated from ReadyNASOS 6.1.8 (1398980083) to 6.1.9 (1409791183).
Here is os_version.log:
ReadyNASOS!!version=6.1.9,time=1409791183,arch=x86_64 - mdgm-ntgrNETGEAR Employee RetiredYes, that is the production 6.1.9 release.
- herbgTutorAny thoughts on next steps or should I try and contact Netgear to open a service ticket?
- herbgTutorI'm in contact with Netgear support and the next step appears to be a full Factory Reset.
The OS Reinstall did not solve the problem. The issue remains ... unable to create a Backup Job on the RN516 that backs up files to my ReadyNAS Pro 6350.
Not very good news ... - mdgm-ntgrNETGEAR Employee RetiredI will take a look at your case #23988706
