herbg
May 11, 2014Tutor
ReadyNAS Pro to RN516 Upgrade
I'm about to buy a RN516 with 6 Seagate 4TB 3.5" SATA3 64MB Cache OEM Hard Drive (ST4000VN000) that I will install myself. I currently keep all my media data on a ReadyNAS Pro 6350.
I intend to use the RN516 as my new media server with the ReadyNAS Pro as my backup (until I run out of space).
A few questions before I start the project:
1) Any tips on the best way to setup the diskless RN516 with the 6 new 4TB drives? Should I start expanding with 1 drive or several installed at once?
2) Once the 516 is setup, I have 8TB of data to move to the RN516. Is there a faster way than setting up a RSync backup from the PRO to the RN516 through the network?
Thanks for your help!
- herbgTutorI'm happy to report that, after escalation at Netgear, this problem was resolved. It appears that the problem was caused by the Backup settings.
So here are the correct settings:
For a share called 'MUSIC'
- Created a job called 'MUSIC'
- Here are the settings for the job:
- General - Name: 'MUSIC'
- Source - Type: share
- Source - Name: share: MUSIC
- Source - Host: (null)
- Source - Path: /
- Source - Login: (null)
- Source - Password: (null)
- Destination - Type: remote
- Destination - Name: remote: Rsync Server
- Destination - Host: (ReadyNAS PRO)
- Destination - Path: MUSIC
- Destination - Login: (null)
- Destination - Password: (null)
- I've left the options under the Advanced, Schedule and Options tabs at defaults.
The critical aspect are the Source:PATH settings: adding the "/" prevents the embedding of a 2nd "MUSIC" folder back into the Destination Share
I'm glad this is resolved. Unfortunately, I wasted much time and effort with the 1st level of Netgear tech support who did not know how to fix this and, at one point, suggested shipping a new unit to solve the problem.
Thanks to StephenB and mdgm for extra-ordinary assistance! - vandermerweMasterInteresting.
Are you needing to do this with 6.2.0 as well? - herbgTutorYes ... this was only tested with 6.20.
- siignaNETGEAR Employee Retired
herbg wrote: I'm happy to report that, after escalation at Netgear, this problem was resolved. It appears that the problem was caused by the Backup settings.
Glad to hear everything's working! Let me know if you see any other oddities.vandermerwe wrote: Interesting.
Off the top of my head I believe this was an issue for 6.1.9 and below, so you'll need to upgrade to 6.2.0 to take advantage.
Looking through the internal bug list seems to confirm that some changes were made in 6.2.0 to ensure that users can utilize both relative and absolute paths on rsync.
