BotanyBay
Dec 04, 2017Tutor
ReadyNAS Pro6 allways boots on power application
I have both a ReadyNAS 626 and a ReadyNAS Pro6 both using the same power source. The 626 does not auto-boot upon application of power after power loss, the Pro 6 does. I have searched the arc...
- Dec 06, 2017Thank you for the update, exactly the information I need.
Dec 05, 2017Guru - Experienced User
Unfortunately Netgear doesn't provide any options to control power-on behavior after a power cut.
A UPS is one workaround, since it ensures that the NAS does a clean shutdown before the UPS battery runs out. The Pro-6 should then stay off when power is restored.
- BotanyBayDec 06, 2017TutorThank you for the update, exactly the information I need.
