nautic_no
Oct 22, 2020Tutor
ReadyNas Pro6 will not start
After a power outage, it will not start. It only show "readynas" in display. Have tried another PSU that are OK. I have upgraded to 6.10. What options do I have?
JohnCM_S
Oct 22, 2020NETGEAR Employee Retired
Hi nautic_no,
Is the NAS still detected on RAIDar?
If it is not detected by RAIDar, you can try removing the disks and see if you will get the same behavior on the NAS. (Note: Label the disks with its corresponding bay before removing them from the NAS)
