nautic_no
Oct 22, 2020Tutor
ReadyNas Pro6 will not start
After a power outage, it will not start. It only show "readynas" in display. Have tried another PSU that are OK. I have upgraded to 6.10. What options do I have?
nautic_no
Oct 22, 2020Tutor
Hi!
As long as the device is not started not net and no raidar. Lan is not active, no net.
I have tried that width no luck. Fans spinning up. Led1 contant red. Will not reset or start. Just ReadnyNAS in display. Is it supposed to take a while? Is there an other way to start?
nautic_no
Oct 22, 2020Tutor
When hold reset down while power up, boot menu is suposed to appear in display. But it do not. Is the reset button faulty? Some advice to clean every connector including CPU and memory. Is that something I should try?
Best regards
Ole Simen
