unita
Dec 03, 2015Aspirant
readynas remote legacy users affected by cloud outage?
I am still unable to connect to my readynas nv+ using readynas remote since the cloud outage. I notice there was a firmware update for readycloud users. is there going to be something equivalent for...
JennC
Dec 04, 2015NETGEAR Employee Retired
Hello unita,
I checked your profile and found that you are using the Sparc based ReadyNAS OS4.
Have you checked if ReadyNAS Remote is still enabled in your ReadyNAS FrontView? I suggest you try turning off the ReadyNAS Remote and turning it back on re-registering your ReadyNAS Remote account to it.
The ReadyCloud server is different from ReadyNAS Remote's. May I also ask for the ReadyNAS Remote add-on version you have on the NAS and the ReadyNAS Remote app version you are using?
