emoacht
May 02, 2011Aspirant
ReadyNAS Remote Monitoring Tool?
Hi, Everyone I am just wondering ... Is there any Windows tool which resides in task tray and remotely monitor the status of ReadyNAS, such as CPU temperature, fan speed and maybe disk usage? If...
Rok1
May 11, 2011Aspirant
InTheShires wrote: NASMon for the Duo, NV/NV+ here
NASMon for the Pro, NVX, here
PHP1.3 for the Duo, NV/NV+ here
PHP1.4 for the Pro, NVX, here
Also, a few tips here http://www.readynas.com/forum/viewtopic.php?f=61&t=50985 to get it working properly, as for some of us it needed some adjusting to get it working better.
PHP1.4 for the Pro is absolutelly danger! At least if RAIDiator 4.2.17 is running.
After the installation, which seems to be ok, it's no longer possible to get access to FrontView at all. Reboot of anything or reinstallation of the ReadyNAS-firmware didn't help - factory reset worked...
Because it was so cool, I tried it twice...
