emoacht
May 02, 2011Aspirant
ReadyNAS Remote Monitoring Tool?
Hi, Everyone I am just wondering ... Is there any Windows tool which resides in task tray and remotely monitor the status of ReadyNAS, such as CPU temperature, fan speed and maybe disk usage? If...
emoacht
Aug 26, 2011Aspirant
Thanks, DotBlog
I am sorry but I have not noticed your post for long time. Anyway, I tried your software, ReadyNAS Monitor Version 1.01, but it periodically shows message "An unhandled exception occured." blinking red signals while it shows temperature of hdd1, hdd2 and system (Temp1), volume usage rate and fan speed correctly.
In the log file, following message repeadedly appears:
My PC's OS is Windows 7 SP1 64bit (language is Japanese, but I do not know it would make any differense though), with .NET Framework 4.0 installed.
My ReadyNAS is ReadyNAS Ultra 2 which RAIDiator version is 4.2.19-T4 and internal language is set to be English (unicode).
I hope it will help debugging your software. If you need more information, please ask.
BTW, before I noticed your post, I almost finished developing my own software by VB.NET for similar purpose. In addtion to showing information from ReadyNAS, it has functions to power on/off the ReadyNAS, etc. It is currently under testing but I hope I will be able to post here shortly.
01:18:58.991; Error;DecodeDisk;Input string was not in a correct format.
01:18:59.057; Error;Unhandled Exception;Object reference not set to an instance of an object.
at ReadyNasMonitor.MainWindow.updateMeters(NasInfo nasInfo) in D:\EnCours\ReadyNasMonitor\ReadyNasMonitor\MainWindow.xaml.cs:line 345
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
