_frantic_
Feb 16, 2016Aspirant
ReadyNAS Replicate: "Connect error code: -51" since firmware update to 6.4.2
I have updated source (RN312) and target (RN104) from 6.4.1. to 6.4.2. Since that, every job failed. Example Log (eMail): [2016-02-16 08:00:05] [Info] Job updated from server
[2016-02-16 08:00:...
- Feb 18, 2016
Apparently there have been some problems with our server recently. Are your Replicate backup jobs completing again now?
JennC
Feb 16, 2016NETGEAR Employee Retired
hello _frantic_,
Please check if source NAS still has Services available and the Internet is marked green under Cloud. If you can access admin page of both NAS units, check the ReadyNAS Remote and ReadyNAS Replicate. Try disabling and re-enabling if you can.
Please also see Communication problems between NASes of article ReadyNAS: Replicate Troubleshooting.
_frantic_
hm, I can see both devices on https://replicate.readynas.com / Views / Network.
Therefore I thought everything should be okay with the devices configurations.
I checked it: "ReadyNAS Remote" and "ReadyNAS Replicate" are active on both devices.
Also, "Internet" and "Services" are marked green on both.
Anyway, I have disabled and re-enabled the services on both devices as suggested.
Tomorrow I will check, wether jobs will run successful again.
Thanks and best regards, _frantic_
