_frantic_
Feb 16, 2016Aspirant
ReadyNAS Replicate: "Connect error code: -51" since firmware update to 6.4.2
I have updated source (RN312) and target (RN104) from 6.4.1. to 6.4.2. Since that, every job failed. Example Log (eMail): [2016-02-16 08:00:05] [Info] Job updated from server
[2016-02-16 08:00:...
- Feb 18, 2016
Apparently there have been some problems with our server recently. Are your Replicate backup jobs completing again now?
_frantic_
hm, I can see both devices on https://replicate.readynas.com / Views / Network.
Therefore I thought everything should be okay with the devices configurations.
I checked it: "ReadyNAS Remote" and "ReadyNAS Replicate" are active on both devices.
Also, "Internet" and "Services" are marked green on both.
Anyway, I have disabled and re-enabled the services on both devices as suggested.
Tomorrow I will check, wether jobs will run successful again.
Thanks and best regards, _frantic_
BrianL2
Feb 16, 2016NETGEAR Employee Retired
Hi _frantic_,
Just let us know if the backup runs again and if not, try to recreate and see if it works.
Kind regards,
BrianL
NETGEAR Community Team
- _frantic_Feb 17, 2016Aspirant
Good: today, only 1 job was scheduled and did run as planned.
Bad: I have started the other jobs manually (https://replicate.readynas.com / Monitor / Run now this instance). They all failed with error code -51.
I have set up a test job and scheduled it ourly.
I will report back...
- BrianL2Feb 17, 2016NETGEAR Employee Retired
Hi _frantic_,
I have just run two backup jobs (at the same time) and it went just fine. Continue with your tests and let us know what happens.
Kind regards,
BrianL
NETGEAR Community Team- mdgm-ntgrFeb 17, 2016NETGEAR Employee Retired
Also, which services and apps are you running on your NAS?
What are your networking settings like? If you don't use IPv6, perhaps you could try disabling that for the network adapter in your NAS?
