_frantic_
Feb 16, 2016Aspirant
ReadyNAS Replicate: "Connect error code: -51" since firmware update to 6.4.2
I have updated source (RN312) and target (RN104) from 6.4.1. to 6.4.2. Since that, every job failed. Example Log (eMail): [2016-02-16 08:00:05] [Info] Job updated from server
[2016-02-16 08:00:...
- Feb 18, 2016
Apparently there have been some problems with our server recently. Are your Replicate backup jobs completing again now?
_frantic_
Feb 18, 2016Aspirant
Not good: today my one-and-only everyday job failed again.
My ourly testjob did not run - I made a user error :-| Will check again tomorrow.
I ran the testjob manually twice: both failed.
BrianL2: did you also upgrade from 6.4.1 to 6.4.2 like I did?
mdgm-ntgr: your questions implies the need to adapt my configuration after an upgrade from 6.4.1 to 6.4.2. Really?
Anyway: both NAS-es have been initialized from scratch last November, both ran fine with 6.4.1, there is no additional software on them. I could send logs etc. But let's not deep dive to early. I would like to know, wether there is a general problem caused by the update to 6.4.2 (or a server problem at the same time).
rteguy: interesting; I am new to replicate since December. Apart from a server failure right in the beginning, the failed/success ratio was about 5% rougly all the time. It is now at 95 % since the day I got 6.4.2 (...or some other misshap perhaps).
Thanks @all, I will report back, when there are any news.
mdgm-ntgr
Feb 18, 2016NETGEAR Employee Retired
- _frantic_Feb 19, 2016Aspirant
...yes, everything went fine during the last 20 hours or so (schedules and manual job runs).
- TonVFeb 19, 2016Aspirant
Having the same error -51, RN104 to RN102, still on 6.4.1
A reboot sometimes seems to help, not sure if that really is the cause though...
Could be the Netgear Replicate server too.... needing a reboot....
- TonVFeb 20, 2016Aspirant
I've done some more tests, getting "Connect Error Code: -51" on multiple jobs and this time rebooting the Source NAS doesn't help :-(
In the description it tells me to check if the source device is online and Replicate service is running, well, that is the case and still error -51.
I did not change anything at all, was working fine yesterday, today it is broken; this happened to me last week as well (thought I had fixed that by rebooting), but not so this time.
It is not 6.4.2 related as I'm still running 6.4.1 on both RN's, for quite some time now, and it was working fine!
Considering MDGMs remark having had some issues on the Netgear Replicate server it seems to me there is still an issue over there...
Would be nice if someone at Netgear would look into this, with no proper alternatives to perform an off site backup we really need Replicate to function well!
Cheers,
Ton - mdgm-ntgrFeb 20, 2016NETGEAR Employee Retired
Can you send me the logs from your two units (see the Sending Logs link in my sig)?
- _frantic_Feb 20, 2016Aspirant
JennC wrote: "...ReadyNAS Remote and ReadyNAS Replicate. Try disabling and re-enabling if you can."
In my experience, this might be more usefull than a reboot - no guarantee :-|
Can you try disabling IPv6 for the NIC (ethernet adapter) in the NAS?
- TonVFeb 22, 2016Aspirant
On my RN104 with 6.4.1 I've disabled IPv6 but that did not fix the issue...
