_frantic_
Feb 16, 2016Aspirant
ReadyNAS Replicate: "Connect error code: -51" since firmware update to 6.4.2
I have updated source (RN312) and target (RN104) from 6.4.1. to 6.4.2. Since that, every job failed. Example Log (eMail): [2016-02-16 08:00:05] [Info] Job updated from server
[2016-02-16 08:00:...
- Feb 18, 2016
Apparently there have been some problems with our server recently. Are your Replicate backup jobs completing again now?
PhysicsTeacher
Feb 28, 2016Aspirant
I am suffering from this issue, as well, but I do not believe that it is associated with a firmware update.
I updated my two units to 4.2.28 on December 6, and Replicate continued to complete successfully for another two months.
Sun Dec 6 14:06:50 EST 2015 System Update Status (LABNAS) : Your ReadyNAS device has been updated with a new firmware image. (RAIDiator-x86 4.2.28)
Sun Dec 6 14:13:52 EST 2015 System Update Status (BKUPNAS) : Your ReadyNAS device has been updated with a new firmware image. (RAIDiator-x86 4.2.28)
Through February 16, my logs typicially look like this:
[2016-02-16 02:00:02] [Info] Job updated from server
[2016-02-16 02:00:02] [Info] Replicate version: 1.2.0 build R1
[2016-02-16 02:00:02] [Info] Starting backup job "System Backup [2014-02-19 04:30 PM]"
[2016-02-16 02:00:02] [Info] Locking target folder: /c/System Backup [2014-02-19 04:30 PM]
[2016-02-16 02:00:04] [Info] Resume folder is "/c/System Backup [2014-02-19 04:30 PM]/2016-02-15 02-00/data"
[2016-02-16 02:03:12] [Info] p2p connect to LABNAS in 2819143 network
[2016-02-16 02:05:49] [Info] Connection method: 5
[2016-02-16 02:05:49] [Warning] Using a relayed connection, consider setting up port forwarding
[2016-02-16 02:05:49] [Info] LAN connection not available
[2016-02-16 02:05:49] [Info] Using p2p connection
[2016-02-16 02:05:49] [Info] Initializing source device
[2016-02-16 02:05:49] [Info] Sending task to source device
[2016-02-16 02:05:51] [Info] Awaiting task report
[2016-02-16 02:05:53] [Info] Received success report
[2016-02-16 02:05:53] [Warning] Snapshot is not requested
[2016-02-16 02:05:53] [Warning] Backup could be inconsistent
[2016-02-16 02:05:53] [Info] Device initialization finished
[2016-02-16 02:05:53] [Info] Starting system config backup
[2016-02-16 02:05:53] [Info] Sending task to source device
[2016-02-16 02:05:56] [Info] Awaiting task report
[2016-02-16 02:06:09] [Info] Received success report
[2016-02-16 02:06:09] [Info] Copy in progress
[2016-02-16 02:13:03] [Info] Copy finished
[2016-02-16 02:13:03] [Info] Deinitialize source device
[2016-02-16 02:13:03] [Info] Sending task to source device
[2016-02-16 02:13:06] [Info] Awaiting task report
[2016-02-16 02:13:08] [Info] Received success report
[2016-02-16 02:13:08] [Info] Device deinitialization finished
[2016-02-16 02:13:08] [Info] p2p disconnect with LABNAS in 2819143 network
[2016-02-16 02:13:09] [Info] Unlock target folder: /c/System Backup [2014-02-19 04:30 PM]
[2016-02-16 02:13:09] [Info] Job finished
Files copied:
Summary:
Copy start time: 2016-02-16 02:06
Total files processed: 507972
Total files transferred: 6
Total files size: 2.51 TB
Total files size transferred: 91.40 MB
Average speed: 225.52 KB/s
Exit code: 0 (Ok)
Copy end time: 2016-02-16 02:13
Beginning on February 17, they all resemble this:
[2016-02-17 02:00:03] [Info] Job updated from server
[2016-02-17 02:00:04] [Info] Replicate version: 1.2.0 build R1
[2016-02-17 02:00:04] [Info] Starting backup job "System Backup [2014-02-19 04:30 PM]"
[2016-02-17 02:00:04] [Info] Locking target folder: /c/System Backup [2014-02-19 04:30 PM]
[2016-02-17 02:00:06] [Info] Resume folder is "/c/System Backup [2014-02-19 04:30 PM]/2016-02-16 02-00/data"
[2016-02-17 02:03:24] [Info] p2p connect to LABNAS in 2819143 network
[2016-02-17 02:03:46] [Info] p2p connect to LABNAS in 2819143 network
[2016-02-17 02:03:58] [Error] Unable to connect to LABNAS
[2016-02-17 02:03:58] [Error] Connect error code: -51
[2016-02-17 02:03:58] [Error] Please check source device is online and Replicate service is running
[2016-02-17 02:03:58] [Info] Unlock target folder: /c/System Backup [2014-02-19 04:30 PM]
[2016-02-17 02:03:58] [Info] Job finished
I do not believe that it is coincidence that my jobs began failing on the same day as other people's jobs. Thoughts?
Bob Breum
_frantic_
For me, the latest series of failed jobs (code -51) started on 2016-02-10.
Every day since that most of all jobs (except one on 2016-02-13 and another one on 2016-02-17) failed until 2016-02-18, 20:00 UTC.
The other day, mdgm posted "Apparently there have been some problems with our server recently.".
PhysicsTeacher wrote:I do not believe that it is coincidence that my jobs began failing on the same day as other people's jobs. Thoughts?
no, your problems started, when my problems began to disappear :-)
So, perhaps they have changed something on the server side...
I have checked my logs and e-mails again:
[2016/02/12 10:28:10] Updated from ReadyNASOS 6.4.1 (ReadyNASOS) to 6.4.2 (ReadyNASOS).
So, that was _after_ the series of failures began for me.
Therefore, I am relatively certain now, that all of this has nothing to do with client versions.
It is more likely related to something on the server side.
