_frantic_
Feb 16, 2016Aspirant
ReadyNAS Replicate: "Connect error code: -51" since firmware update to 6.4.2
I have updated source (RN312) and target (RN104) from 6.4.1. to 6.4.2. Since that, every job failed. Example Log (eMail): [2016-02-16 08:00:05] [Info] Job updated from server
[2016-02-16 08:00:...
- Feb 18, 2016
Apparently there have been some problems with our server recently. Are your Replicate backup jobs completing again now?
BlackShark
Mar 02, 2016Aspirant
Same Issue, Its seem that when you manually force it few time it go trought but yes automanic randomly fail -> Netgear server Issue
But I have to say netgear RN516 & replicate is awsome :) my only exceptation is that I hope in some way the will proceed a Full system back up instead of folders in the futur
Log:
[2016-03-02 15:01:28] [Info] Replicate version: 1.3.0 build R2
[2016-03-02 15:01:28] [Info] Starting backup job "Transfert"
[2016-03-02 15:01:28] [Info] Locking target folder: /data/***
[2016-03-02 15:01:28] [Info] Resume folder is "/data/*** (failed)/data"
[2016-03-02 15:01:35] [Info] p2p connect to NAS*** in 881*** network
[2016-03-02 15:01:58] [Info] p2p connect to NAS*** in 881*** network
[2016-03-02 15:02:11] [Error] Unable to connect to NAS***
[2016-03-02 15:02:11] [Error] Connect error code: -51
[2016-03-02 15:02:11] [Error] Please check source device is online and Replicate service is running
[2016-03-02 15:02:11] [Info] Unlock target folder: /data/***
[2016-03-02 15:02:11] [Info] Job finished
Log:
[2016-03-02 15:04:40] [Info] Replicate version: 1.3.0 build R2
[2016-03-02 15:04:40] [Info] Starting backup job "Transfert"
[2016-03-02 15:04:40] [Info] Locking target folder: /data/***
[2016-03-02 15:04:40] [Info] Resume folder is "/data/*** (failed)/data"
[2016-03-02 15:04:58] [Info] p2p connect to NAS*** in 881*** network
[2016-03-02 15:04:58] [Info] Connection method: 0
[2016-03-02 15:04:58] [Info] LAN connection not available
[2016-03-02 15:04:58] [Info] Using p2p connection
[2016-03-02 15:04:58] [Info] Initializing source device
[2016-03-02 15:04:58] [Info] Sending task to source device
[2016-03-02 15:05:05] [Info] Awaiting task report
[2016-03-02 15:05:08] [Info] Received success report
[2016-03-02 15:05:08] [Info] Device initialization finished
[2016-03-02 15:05:08] [Info] Copy in progress
[2016-03-02 15:05:13] [Info] Copy finished
[2016-03-02 15:05:13] [Info] Deinitialize source device
[2016-03-02 15:05:13] [Info] Sending task to source device
[2016-03-02 15:05:15] [Info] Awaiting task report
[2016-03-02 15:05:17] [Info] Received success report
[2016-03-02 15:05:17] [Info] Device deinitialization finished
[2016-03-02 15:05:17] [Info] p2p disconnect with NAS*** in 881*** network
[2016-03-02 15:05:17] [Info] Unlock target folder: /data/***
[2016-03-02 15:05:17] [Info] Job finished
Summary:
Copy start time: 2016-03-02 15:05
Total files processed: 15731
Total files transferred: 0
Total files size: 233.98 GB
Total files size transferred: 0 B
Average speed: 0 B/s
Exit code: 0 (Ok)
Copy end time: 2016-03-02 15:05
- TonVMar 05, 2016Aspirant
Well, all seems to be working again for me, didn't change anything on my side but all my jobs ran over the weekend...
I guess the Netgear Replicate server is feeling better again, hopefully it stays that way :-)
(and I hope it works for the other people as well...)
It would be nice if Netgear would finally enable to UPLOAD an SSH key through the GUI, that would make life easier to setup RSYNC over SSH.
But for reasons totally unclear to me there is only the option to download this key... (so you can RSYNC over SSH to a different brand NAS, but not to a Netgear NAS :-( )
Cheers!
