mamoru77
Aug 11, 2015Aspirant
Readynas RN102 "disk is full" error + device offline (6.2.5)
Hello, during the past days I experienced the "disk is full" error when trying to copy files from my pc to the readynas disk (4TB / less than 2 used). In the past this happened once and it was d...
mdgm-ntgr
Aug 11, 2015NETGEAR Employee Retired
Can you first check that there is plenty of free space on the 4GB OS partition and then download the logs using RAIDar 6.0 and send them in (see the Sending Logs link in my sig)?
- mamoru77Aug 11, 2015Aspirant
Thank you for the quick reply :)
I will install Raidar 6 and check asap
from ssh console I run:
root@NAS-JP:/# df -a -h Filesystem Size Used Avail Use% Mounted on rootfs 4.0G 975M 2.9G 26% / tmpfs 10M 4.0K 10M 1% /dev devpts 0 0 0 - /dev/pts /dev/md0 4.0G 975M 2.9G 26% / proc 0 0 0 - /proc sysfs 0 0 0 - /sys tmpfs 248M 0 248M 0% /dev/shm tmpfs 248M 500K 248M 1% /run tmpfs 248M 0 248M 0% /sys/fs/cgroup cgroup 0 0 0 - /sys/fs/cgroup/systemd cgroup 0 0 0 - /sys/fs/cgroup/cpu cgroup 0 0 0 - /sys/fs/cgroup/blkio tmpfs 248M 0 248M 0% /media configfs 0 0 0 - /sys/kernel/config fusectl 0 0 0 - /sys/fs/fuse/connections /dev/md127 2.8T 1.2T 1.6T 42% /data /dev/md127 2.8T 1.2T 1.6T 42% /home /dev/md127 2.8T 1.2T 1.6T 42% /apps tmpfs 4.0K 0 4.0K 0% /data/Common/snapshot tmpfs 4.0K 0 4.0K 0% /data/readydrop/snapshot tmpfs 4.0K 0 4.0K 0% /data/Transmission/snapshot tmpfs 4.0K 0 4.0K 0% /data/バックアップ/snapshot tmpfs 4.0K 0 4.0K 0% /home/user/snapshot tmpfs 4.0K 0 4.0K 0% /data/home/user/snapshot
In the meantime I found on another post how to check for apache2 errors and I got this:
root@NAS-JP:/# systemctl status -a apache2 apache2.service - The Apache HTTP Server Loaded: loaded (/lib/systemd/system/apache2.service; enabled) Active: failed (Result: exit-code) since Wed, 12 Aug 2015 08:38:25 +0900; 58min ago Process: 2058 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE) Process: 2054 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS) CGroup: name=systemd:/system/apache2.service Aug 12 08:38:24 NAS-JP fvapps[2054]: /frontview/bin/fvapps: line 6: /apps/.tobedelete: No space left on device Aug 12 08:38:25 NAS-JP apache2[2058]: apache2: Syntax error on line 268 of /etc/apache2/apache2.conf: Syntax error on line 6 of /etc/apache2/sites-enabled/000-fv-http: Syntax error on line 12 of /etc/frontview/apache/apps-https.conf: Could not open configuration file /apps/smbplus/https.conf: No such file or directory- mdgm-ntgrAug 11, 2015NETGEAR Employee Retired
With apache dead you won't be able to download the logs.
Will send you a PM.
