mamoru77
Aug 11, 2015Aspirant
Readynas RN102 "disk is full" error + device offline (6.2.5)
Hello, during the past days I experienced the "disk is full" error when trying to copy files from my pc to the readynas disk (4TB / less than 2 used). In the past this happened once and it was d...
mamoru77
Thank you for the quick reply :)
I will install Raidar 6 and check asap
from ssh console I run:
root@NAS-JP:/# df -a -h Filesystem Size Used Avail Use% Mounted on rootfs 4.0G 975M 2.9G 26% / tmpfs 10M 4.0K 10M 1% /dev devpts 0 0 0 - /dev/pts /dev/md0 4.0G 975M 2.9G 26% / proc 0 0 0 - /proc sysfs 0 0 0 - /sys tmpfs 248M 0 248M 0% /dev/shm tmpfs 248M 500K 248M 1% /run tmpfs 248M 0 248M 0% /sys/fs/cgroup cgroup 0 0 0 - /sys/fs/cgroup/systemd cgroup 0 0 0 - /sys/fs/cgroup/cpu cgroup 0 0 0 - /sys/fs/cgroup/blkio tmpfs 248M 0 248M 0% /media configfs 0 0 0 - /sys/kernel/config fusectl 0 0 0 - /sys/fs/fuse/connections /dev/md127 2.8T 1.2T 1.6T 42% /data /dev/md127 2.8T 1.2T 1.6T 42% /home /dev/md127 2.8T 1.2T 1.6T 42% /apps tmpfs 4.0K 0 4.0K 0% /data/Common/snapshot tmpfs 4.0K 0 4.0K 0% /data/readydrop/snapshot tmpfs 4.0K 0 4.0K 0% /data/Transmission/snapshot tmpfs 4.0K 0 4.0K 0% /data/バックアップ/snapshot tmpfs 4.0K 0 4.0K 0% /home/user/snapshot tmpfs 4.0K 0 4.0K 0% /data/home/user/snapshot
In the meantime I found on another post how to check for apache2 errors and I got this:
root@NAS-JP:/# systemctl status -a apache2
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled)
Active: failed (Result: exit-code) since Wed, 12 Aug 2015 08:38:25 +0900; 58min ago
Process: 2058 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE)
Process: 2054 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
CGroup: name=systemd:/system/apache2.service
Aug 12 08:38:24 NAS-JP fvapps[2054]: /frontview/bin/fvapps: line 6: /apps/.tobedelete: No space left on device
Aug 12 08:38:25 NAS-JP apache2[2058]: apache2: Syntax error on line 268 of /etc/apache2/apache2.conf: Syntax error on line 6 of /etc/apache2/sites-enabled/000-fv-http:
Syntax error on line 12 of /etc/frontview/apache/apps-https.conf: Could not open configuration file /apps/smbplus/https.conf: No such file or directory
mdgm-ntgr
Aug 11, 2015NETGEAR Employee Retired
With apache dead you won't be able to download the logs.
Will send you a PM.
