Tibonhomme
Sep 27, 2023Tutor
ReadyNAS rn10200 strange startup (blue blink)
Hey there, I use the readyNAS RN10200. I'm new at this. I tried it with two small disks and it worked just fine. I decided to go with one faster and larger disk only, so i turned it off, ...
NiveditaP3
Sep 27, 2023NETGEAR Expert
Hello Tibonhomme ,
Could you please check the Hard-disk compatibility with your ReadyNAS first. HDD compatibility reference link : https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
Then you can check if your device is discover on Raidar. Link for reference for Basic Setup with RAIDar : https://kb.netgear.com/22765/Basic-Setup-with-RAIDar
Also , If you ReadyNAS was not running on latest firmware then you can perform OS reinstall by accessing the boot menu. OS-reinstall is a safe method and the data is not impacted at all. Link for reference to access the boot menu on RN102 : https://kb.netgear.com/22892/How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312
Have a lovely day,
Nivedita Pa
Netgear Team
Sandshark
Sep 29, 2023Sensei
NiveditaP3 wrote:Hello Tibonhomme ,
Are you serious? The hard disk compatibility list is 100% useless, containing no recent entries and many entries for drives that have not been manufactured for years. There are even entries that would lead one to believe the current WD Red line (as opposed to Red Plus) are a good choice, which they absolutely are not, because they are "from a similar product line" (which they are actually not, in spite of using the same name).
It is a shame that the current moderation of this forum consists of canned answers from years past and not real answers from someone with appropriate technical knowledge.
