everytime
Feb 19, 2016Guide
How do I remove a Route?
I recently had problems with ReadyCloud and started trying to find other ways to access my network remotely. One of the things I looked into was Port Forwarding and that led me to create a Route (Net...
everytime
Feb 21, 2016Guide
Hi, Jenn. I've tried what you suggested: I cleared the caches on both browsers. I closed and reopened them too. The Route was still there. I tried to remove it again, but with no luck. Then I tried a different computer on the network, didi the same things, but it too didn't remove the Route.
This is curious. What should I try next?
Thank you for your help.
mdgm-ntgr
Feb 21, 2016NETGEAR Employee Retired
If you disable teaming are you then able to delete the route? Also, there are better teaming options than adaptive load balancing.
- everytimeFeb 23, 2016Guide
I was unsure how to go about disabling teaming safely, but I did some more research in the Netgear Knowledgebase.
I changed the Teaming Mode (Network > Links > Mode) to Round-Robin and when I went back to Routes, the recalcitrant route was gone.
Thanks much for your assistance.
- JennCFeb 23, 2016NETGEAR Employee Retired
Hello everytime,
That must be what mdgm was suggesting.
Anyway, it's good to hear it's gone now.
