77PALE77
Jun 08, 2017Apprentice
ReadyNAS RN104 stuck and not working after 6.7.4 firmware install
Hi everybody, after the last 6.7.4 firmware update my RN104 has strange behaviour. Sometimes it gets stuck and the only way to reboot it is to pull the AC plug. The front button or the back reset ...
77PALE77
I'll check logs as soon as possible.
Don't know what SMART stats are... can you please explain?
Thanks a lot
77Pale77
Thanks a lot
77Pale77
Jun 08, 2017Guru - Experienced User
There's a general overview of SMART here: https://en.wikipedia.org/wiki/S.M.A.R.T.
Once you get the logs, you'll see them in disk_info.log.
- 77PALE77Jun 08, 2017Apprentice
Here is my logs, only yellow dotted ones, saying about disk space less than 20-30%, as I can understand!
do you see something worse?
Thanks a lot!
Thu Jun 8 2017 22:39:47
System: Set locale to en-us.
Thu Jun 8 2017 16:01:05
System: ReadyNASOS background service started.
Thu Jun 8 2017 16:00:49
Volume: Less than 20% of volume data's capacity is free. Performance on volume data will degrade if additional capacity is consumed. NETGEAR recommends that you add capacity to avoid performance degradation.
Thu Jun 8 2017 16:00:45
System: ReadyNASOS service or process (readynasd) was restarted.
Thu Jun 8 2017 15:44:42
System: Antivirus scanner definition file was updated to 58.23455.
Thu Jun 8 2017 15:28:02
Thu Jun 8 2017 15:27:58
Thu Jun 8 2017 15:27:55
System: ReadyNASOS service or process was restarted.
Thu Jun 8 2017 8:01:56
Thu Jun 8 2017 8:01:52
Thu Jun 8 2017 2:00:07
System: The system is shutting down.
Wed Jun 7 2017 8:19:23
System: Antivirus scanner definition file was updated to 57.23452.
Wed Jun 7 2017 8:01:59
Wed Jun 7 2017 8:01:55
Wed Jun 7 2017 2:00:07
Tue Jun 6 2017 11:37:54
Tue Jun 6 2017 10:26:38
System: Antivirus scanner definition file was updated to 57.23450.
Tue Jun 6 2017 10:10:04
Tue Jun 6 2017 10:09:58
Volume: Less than 30% of volume data's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%.
Mon Jun 5 2017 16:38:24
Mon Jun 5 2017 8:18:59
System: Antivirus scanner definition file was updated to 57.23448.
Mon Jun 5 2017 8:01:58
Mon Jun 5 2017 8:01:54
Mon Jun 5 2017 2:00:07
Sun Jun 4 2017 18:39:06
Sun Jun 4 2017 18:39:04
Sun Jun 4 2017 18:34:46
Sun Jun 4 2017 18:28:45
Sun Jun 4 2017 18:28:23
Sun Jun 4 2017 18:28:11
Sun Jun 4 2017 18:12:54
System: Antivirus scanner definition file was updated to 57.23446.
Sun Jun 4 2017 18:12:27
Account: User 'Lu' was added.
Sun Jun 4 2017 17:53:42
Sun Jun 4 2017 17:53:38
Sun Jun 4 2017 17:53:34
Sun Jun 4 2017 17:42:08
Sun Jun 4 2017 17:42:05
Sun Jun 4 2017 17:42:01
Sun Jun 4 2017 8:18:52
System: Antivirus scanner definition file was updated to 57.23445.
Sun Jun 4 2017 8:01:54
Sun Jun 4 2017 8:01:51
Sun Jun 4 2017 8:01:48
Sat Jun 3 2017 23:43:53
System: Antivirus scanner definition file was updated to 57.23444.- 77PALE77Jun 08, 2017Apprentice
Sorry...
and here is the disklog detail...
I'm not so smart but I see no error
Device: sdd Controller: 0 Channel: 0 Model: ST31000333AS Serial: XXXXXXXXX Firmware: SD15 Class: SATA RPM: 7200 Sectors: 1953525168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe556a2 Health data ATA Error Count: 0 Reallocated Sectors: 100 Reallocation Events: 100 Spin Retry Count: 66 End-to-End Errors: 0 Command Timeouts: 9 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 46 Start/Stop Count: 6376 Power-On Hours: 9999 Power Cycle Count: 1604 Device: sdc Controller: 0 Channel: 1 Model: WDC WD10EAVS-00D7B0 Serial: WD-WCXXXXXXXXXX Firmware: 01.01A01 Class: SATA Sectors: 1953525168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe556a2 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 46 Start/Stop Count: 1664 Power-On Hours: 6694 Power Cycle Count: 555 Load Cycle Count: 1659 Device: sdb Controller: 0 Channel: 2 Model: WDC WD30EURX-63T0FY0 Serial: WD-WCXXXXXXXXXXX Firmware: 80.00A80 Class: SATA RPM: 5400 Sectors: 5860533168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe556a2 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 44 Start/Stop Count: 1274 Power-On Hours: 5549 Power Cycle Count: 1271 Load Cycle Count: 1236 Device: sda Controller: 0 Channel: 3 Model: ST4000DM000-1F2168 Serial: XXXXXXXX Firmware: CC54 Class: SATA RPM: 5900 Sectors: 7814037168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 2fe556a2 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 2 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 40 Start/Stop Count: 1196 Power-On Hours: 5439 Power Cycle Count: 1195 Load Cycle Count: 1827
- mdgm-ntgrJun 09, 2017NETGEAR Employee Retired
Please send me your logs (see the Sending Logs link in my sig).
