77PALE77
Jun 08, 2017Apprentice
ReadyNAS RN104 stuck and not working after 6.7.4 firmware install
Hi everybody, after the last 6.7.4 firmware update my RN104 has strange behaviour. Sometimes it gets stuck and the only way to reboot it is to pull the AC plug. The front button or the back reset ...
77PALE77
Jun 09, 2017Apprentice
Thanks a lot.
Can you please post the exact row where I can see it?
How can I solve it and on what is it depending?
- StephenBJun 10, 2017Guru - Experienced User
77PALE77 wrote:
Can you please post the exact row where I can see it?Reallocated Sectors: 100 Reallocation Events: 100
77PALE77 wrote:
How can I solve it?You need to replace the disk. I suggest either a WD Red or a Seagate Ironwolf.
- 77PALE77Jun 10, 2017Apprentice
Ok thank you!
I think 10Tb Ironwolf should be the right choice to increase my NAS capacity too. What do you think about it?
Can you please link the procedure to replace disk? My NAS is Xraid formatted.
Thank you very much!!!
77Pale77
- StephenBJun 11, 2017Guru - Experienced User
I think Ironwolf (and WDC Reds) are generally good choices to ReadyNAS.
But I think the RN104 will struggle with volumes that big. Four jbod volumes will certainly be ok, but there is no RAID protection if you use that mode. Perhaps flexraid with two 2x10TB RAID-1 volumes will work out, but I think 4x10TB single or dual redundancy will be pushing things. Volume rebuild times will be very long.
With normal XRAID, 4 TB drives are a more typical size in an RN104.
You do want to back up the data first, since the volume is vulnerable during expansion.
Then you can just remove an old disk, and hot-insert a new disk (all with the NAS running). Then wait for the volume rebuild to complete before you do the next disk. As the volume size grows, the wait will become longer.
