davor242
Nov 18, 2017Aspirant
Readynas RN204 - Stuck at Booting... 42%
RN204, OS 6.9.0 Noticed iSCSI misbehaving (no connection, normal shares operational), logged on web GUI, initiated reboot. Reboot stuck on "see you soon". Power-button no reaction. Eventually po...
Nov 18, 2017Guru - Experienced User
I suggest paid support (my.netgear.com)
davor242
StephenB wrote:I suggest paid support (my.netgear.com)
That sounds serious. :O
Is it "oh yeah, known problem, don't use iSCSI, you are f*cked but paid support can help you recover the data" or "Have not seen this particular sequence earlier, maybe support'll know"........?
- davor242Nov 19, 2017Aspirant
Good news!
I switched off NAS. Took out the drives and went to bed. And the good news part:
This morning I booted the NAS without drives.
Then I switched off the NAS.
Put in the (3) drives in again (in random order).
Switched on the NAS and it magically works again!
Log: Disk: Disk in channel 1 (Internal) changed state from ONLINE to RESYNC.
The iSCSI just dropped out again. :O
Restaring NAS after iSCSI problems -> stuck on "Restarting Now See You Soon".
Note: the NAS thinks there is an iSCSI connection from the PC, the PC thinks otherwise and is not able to reconnect.
Noticed that the btrfs-transacti command was using 100% CPU before I was kicked out of SSH.
Booting. Stuck at 42% for long time again. So same symptoms as before. *waiting*. NAS is not visible to RAIDar at this point. udev-settle.service issues? 25+ minutes now.
- StephenBNov 19, 2017Guru - Experienced User
Closer to the latter. Failure to boot with possibility of data loss, complicated by the fact that iSCSI data is opaque to the NAS. I was assuming that you had no backup (though that was a guess).
Though it looks like you've also installed stuff with ssh (pilgrim anyway), which could complicate things further.
Any idea what mount is mounting?
I only installed mc (midnight commander).
pilgrim appears to be what controls the front panel LCD of the NAS.
Usage: pilgrim [-c] [-l path] [ -p path] [-s hex] [-t "term cmd"] [-u file]
-c Clear LCD on termination
-l Message list file path(/var/readynasd/pilgrim.list)
-p Socket path (\0/org/freedesktop/plymouthd)
-s Solid box character code in hex (ff)
-t Termnation cmd (none)
-u Termnation unit ("readynasd.service")Still at 98%.
/bin/mount /dev/disk/by-label/1177b17c:data /data -t btrfs
