yates
Feb 26, 2016Aspirant
ReadyNAS RN2120 painfully slow.
I apologize if this has been covered but could not find an answer that helps me. I work for a manufacturing company and we use an RN2120 to save normal PDFs, Microsoft office files, pictures, and...
yates
I have tried disabling the antivirus with no impact either way. I will give it a shot again today though just to make sure. I am currently running the 6.4.0 firmware rather than the knewer firmware.
yates
Small update; disabling the antivirus did have a small improvement (maybe 50% faster load times) on pictures, I have not heard back on the solidworks files.
- JennCFeb 26, 2016NETGEAR Employee Retired
Hello yates,
For the meantime, disable antivirus. Fix is being developed and hopefully next month is its release.
- yatesFeb 26, 2016Aspirant
Just so that I am understanding, this is a software issue with this model of NAS and not a hardware issue that the NAS is not finding? I just need to report to the powers that be on the progress of repair.
Also, is going to be a fix for slowness even after I disabled the antivirus? If the speed is only going to be as good as it is with the antivirus disabled then I will need to look into alternative storage.
- cpu8088Feb 26, 2016Virtuoso
dodgy ethernet cables can be the culprit
make sure u have gigabit connection
