pgjscottieuk
Jan 15, 2019Guide
Readynas RN516 Exporting a Volume
Hi i would like to Export a Volume which is at the moment A backup From a Readynas 516
The export is on a Readynas RN316 and i want to Export/Migrate this backup To Another Readynas 516
When it i...
- Jan 16, 2019
DO NOT use the export function for what you want to do. It's obviously intended for exporting a single volume of a multi-volume NAS. Export/Import does change all the file and share attributes. I assume that's because there is no guarantee that the user and group UIDs will be the same on the new as on the old. I'n not really sure if it's the export or the import that makes the change, since you can't tell it's changed until you do both. But I've assumed that's the reason for "Export".
pgjscottieuk
Jan 15, 2019Guide
Thank you it is already running 6.9.4 Hotfix 1
Sandshark
Jan 16, 2019Sensei
- pgjscottieukJan 16, 2019Guide
Thank you for the loud and clear instrucion i had printed of both the Exporting A Volume And The Migrating A Volume I think The Netgear Atricles could make this clearer as it results in People like myself comimg to the forum which ultimately helps others if they read the posts but takes time when working across time zones
But thank you for all the input from everyone Steve has helped a lot in the past thanks again
