RobertD
Feb 14, 2017Aspirant
Readynas rnd2000 v2 firmware upgrade
After a recent power failure (despie being on UPS) my ReadyNAS no longer works. Both green drive leds are lit & the working(CPU..?) led flashes occasionally. The Blue power led gives 4 slow flashe...
- Feb 15, 2017
That disk has failed very badly. With that high an error count presumably there would have been some SMART errors occurring for quite some time.
Replacing that disk with a new disk would certainly be worth a try.
Do you have a backup? Is that up to date?
mdgm-ntgr
Feb 14, 2017NETGEAR Employee Retired
Are you sure you have a v2? Your profile shows that you bought a v1 just over 5 years ago now.
Please see How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
- RobertDFeb 14, 2017Aspirant
Mine is definately a Version 1.....
but the model number sticker shows RND2000 v2
(I did try to make that plain in the post, but I had to try several times...seems the final post that eventually went was missing that bit)
- mdgm-ntgrFeb 15, 2017NETGEAR Employee Retired
One of your disks (probably disk 1) is bad
It has a current pending sector count of 24 and an ATA error count of 18970- RobertDFeb 15, 2017Aspirant
Have to admit - that doesnt mean much to me.
So if I replace that disk - it should fix the problem..??
I thought running raid - it would function with one disk down..??
Do you have a backup? Is that up to date?- RobertDFeb 15, 2017Aspirant
No, I have no backups.
The whole idea of having the Raid server was to provide safe (backedup in the array) storage.
