arip's avatar
arip
Readynas rnd2000 v2 password reset issue
Hello,   I'm trying to reset the admin password on my readynas RND2000 v2 via the <enter IP address>/password_recovery approach. I have entered the correct details (modal box appears with success ...
  • StephenB's avatar
    Jan 09, 2017
    bedlam1 wrote:
    arip wrote:
    PS: one final question, should the ethernet cable still be connected when  doing an OS reinstall?
    Should make no difference, check your DNS and other settings after re-install though
    The IP configuration will be reset to use factory defaults (DHCP).
ProSupport for Business
