arip
Jan 07, 2017Aspirant
Readynas rnd2000 v2 password reset issue
Hello, I'm trying to reset the admin password on my readynas RND2000 v2 via the <enter IP address>/password_recovery approach. I have entered the correct details (modal box appears with success ...
arip
Many thanks - have a great day
PS: one final question, should the ethernet cable still be connected when doing an OS reinstall?
- bedlam1Jan 07, 2017Prodigy
arip wrote:PS: one final question, should the ethernet cable still be connected when doing an OS reinstall?
Should make no difference, check your DNS and other settings after re-install though
- StephenBJan 09, 2017Guru - Experienced User
The IP configuration will be reset to use factory defaults (DHCP).
