arip
Jan 07, 2017Aspirant
Readynas rnd2000 v2 password reset issue
Hello, I'm trying to reset the admin password on my readynas RND2000 v2 via the <enter IP address>/password_recovery approach. I have entered the correct details (modal box appears with success ...
Sandshark
Jan 07, 2017Sensei
Password reset should work, but it relies on the SMTP server and email address you specified in the set-up. If anything chaged there, it would fail. Are you getting notification from the NAS (if you have any enabled)?
But an OS re-install is always there as a last resort.
