Wystell
Apr 18, 2018Aspirant
ReadyNas RND4000 NV+ V2 stuck booting
I have a ReadyNas RND4000-200NAS NV+ V2 which has 4 disks (2x3TB Seagate NAS Drive, 2x750GB Seagate drives) and was configured using XRaid I believe. The NAS was running the most recent version of Ra...
Jul 14, 2018Guru - Experienced User
I think the next step is to power down the NAS and test the disks in a Windows PC using vendor tools (seatools for seagate, lifeguard for western digital). Disks can be connected either with SATA or a USB adapter/dock.
AMER31 wrote:
Can ping the NAS but admin page is not accessable at all
If you are booting diskless, than that is expected. The boot flash doesn't include a web interface.
AMER31 wrote:
Can do telnet
This is with disks installed, and using tech support mode?
AMER31 wrote:
try to re-install OS but no good
Did you try this using the front panel, or from telnet?
- StephenBJul 15, 2018Guru - Experienced User
Two ATA errors sounds healthy to me, though it is still worth running seatools on all the disks.
AMER31 wrote:
Forgot to mention that still admin page is not accessable
I think the first goal is to extract any data on the NAS, so you have a full backup of the contents. Without a backup, we need to be more cautious. Do you have data you need to extract?
If you have access via SMB, etc you could simply do a drag/drop of all the files to external storage.
