micb
Jan 08, 2019Aspirant
ReadyNAS slow write speed
Hi,
We have very very slow write speed saving open files. eg 280MB file takes 10 minutes to save??, however only takes 5 seconds to paste same file from PC to NAS. Takes 20 seconds to save same fil...
micb
Jan 09, 2019Aspirant
Hi Roland and Stephen,
Thankyou!
Thanks for fast response and you have solved our issue!! Believe it was unchecking 'strict sync' as you described. Our 280MB file now saves in 20 sec instead of 20minutes!! what a relief! Thanks again.
I have left the disc spin down function on also..
cheers
Mic.
Jan 10, 2019Guru - Experienced User
Great!
That should be fine.
SMB transport encryption can also slow down your particular NAS, because the RN300 series doesn't have hardware support for encryption. If your security policies don't require SMB transport encryption you can try turning it off and see if you get any further speedup.
Personally I'd leave quota and snapshots enabled, as I think they are worth the performance hit. Note that enabling quota for the volume gives you better visibility into volume space usage (which is helpful even if you don't set quotas).
For snapshots, you do need to take the "churn" into account, as the space needed can build up quickly. If you have applications that update files in place frequently (for instance, databases), then you shouldn't use snapshots on those shares. I recommend using custom snapshots instead of the default "smart" snapshots - setting a max retention, so the snapshot use will continue to grow over time. With BTRFS you do want to keep at least 20% free space.
Running the balance and defrag maintenance functions periodically can also help maintain performance. However, they can take a while to complete (especially if they've never been run), and performance will drop while they are running. So perhaps try running a balance over the weekend (assuming usage is light then). You can cancel it if the performance impact is too much. I run each of the maintenance functions once every three months.
- Retired_MemberJan 10, 2019
StephenB wrote "However, they (defrag and balance) can take a while to complete (especially if they've never been run), and performance will drop while they are running"
You can nearly completely avoid the necessary effort to defragment by using a special feature of app smb-plus. There is an option to pre-allocate diskspace when writing files to the nas' volumes. This feature will most probably make sure, that the files are written unfragmented. The minor degradation in writing performance is so marginal, that it is more than worth to switch on this feature.
Kind regards
