chsu83
May 10, 2018Luminary
Readynas Snapshot usage
Hey together,
Attention - I'm not responsible if you damage your NAS. This is not a built in function.
Just had again the problem that I'd like to know which snapshot is consuming a lot of space, because sometimes it is so hard to know where, and if it makes sense.
Found this script here: https://ownyourbits.com/2017/12/06/check-disk-space-of-your-btrfs-snapshots-with-btrfs-du/
wget https://raw.githubusercontent.com/nachoparker/btrfs-du/master/btrfs-du -O /usr/local/sbin/btrfs-du chmod +x /usr/local/sbin/btrfs-du
runned the script on my btrfs volume like:
btrfs-du /data/
actually it seems like it could be working. (at least after the change: https://github.com/nachoparker/btrfs-du/issues/9#issuecomment-380427001 ). But I have to verify a little more.
Perhaps some people here, which are knowing readynas better than me would also take an eye on it?
1 Reply
- Anonymous
Hi chsu83, thanks for letting the community know.
- Jun 06, 2017Anonymous
