fwdnetad
Jun 03, 2016Aspirant
ReadyNas snapshots disapeared after 6.5 upgrade
I was unable to delete some older snapshots. They were taking up almost 7TB of space. So I upgraded the firmware. Now I cant see those older snapshots but the system still shows that snapshots are...
- Jun 06, 2016
It might be recomputing the quotas. I'd stay with the deletions (oldest snapshots first). You can delete more than one at a time.
Jun 03, 2016Guru - Experienced User
You might need netgear help on this (or just do a factory reset and rebuild the NAS).
It's possible to delete the snapshots via ssh, but that probably isn't enough. It reclaims the space, but it doesn't fix the ReadyNAS SQL database.
fwdnetad
Jun 06, 2016Aspirant
So I ran the following:
# touch /.force_snapshots_upgrade # systemctl restart readynasd
That broght back the old snapshots but now my readynas is terribly slow. Unusably slow.
- Jun 06, 2017Retired_Member
