fwdnetad
Jun 03, 2016Aspirant
ReadyNas snapshots disapeared after 6.5 upgrade
I was unable to delete some older snapshots. They were taking up almost 7TB of space. So I upgraded the firmware. Now I cant see those older snapshots but the system still shows that snapshots are...
- Jun 06, 2016
It might be recomputing the quotas. I'd stay with the deletions (oldest snapshots first). You can delete more than one at a time.
fwdnetad
Jun 06, 2016Aspirant
I am in the process. They do delete but it takes forever for eachone to delete. At this rate it will take me the rest of the day to get them all deleted.
Jun 06, 2016Guru - Experienced User
- fwdnetadJun 06, 2016Aspirant
I got all those old ones deleted and everything is running smoothly now. The space from the snapshots hasn't been reclaimed though.
- fwdnetadJun 07, 2016Aspirant
All the space is now reclaimed. Thanks for your help.
- BrianL2Jun 07, 2016NETGEAR Employee Retired
Hi fwdnetad,
Thanks for the update. You may now close this thread by clicking the "Accept as Solution" button in one of the responses that you received. In addition to what you did, it would also help if you will create a schedule maintenance for volume defragmentation and balance.
Kind regards,
BrianL
NETGEAR Community Team
- Jun 06, 2017Retired_Member
