steveoelliott
Feb 23, 2009Luminary
Readynas Stuck in Booting...
Hi, As requested started a new thread... My box is stuck in the booting state and always takes at least 4-5 hours to boot. I've tried all the options. USB and TFTP updates etc and I've now got a...
steveoelliott
Ok thanks, I will try and get these later. The last time the box came up the web interface was really slow and didn't display the content inside the frames. This was after using the reset 5 seconds firmware installation. Therefore I'm not sure if I will have difficulty getting the logs but I shall certainly try. Hopefully that won't happen this time.
I will be heading off home in around 30 mins but if in the end you deem it necessary to access this box remotely I am able to come back and sort that out. I only live 8 miles from here.
