kcrossley
Jul 25, 2011Aspirant
ReadyNAS Temperature?
What temperature does your ReadyNAS operate at? Will keeping the ReadyNAS cooler improve its life?
ChrisMc73
Aug 11, 2011Aspirant
claykin wrote: Provided those are F temp readings you're OK. No need to move the NAS unless you feel you want to try to achieve cooler temps.
Claykin,
My temps are similar, maybe a little higher up to 114 on a few (still in a normal range). My NV+ is in a mid sized wooden cabinet, where I have put my UPS, Router, Cable Modem and hidden the mess of cable & wires with all these devices. I had to drill (3) 1&1/2" holes in the back of it to run the cables. Im a little worried about that fan, it seems to run all the time, is that normal? Should I relocated the NV+ outside the cabinet, so that it has open air, and runs in a lower than triple digit range?
Device Description Status
Disk 1 Seagate ST31500341AS 1397 GB , 40 C / 104 F
Disk 2 Seagate ST31500341AS 1397 GB , 44 C / 111 F
Disk 3 Seagate ST31500341AS 1397 GB , 43 C / 109 F
Disk 4 Seagate ST31500341AS 1397 GB , 40 C / 104 F
Fan 1 3409 RPM
Temp 1 33.0 C / 91 F [Normal 0-60 C / 32-140 F]
UPS 1 CPS CP 1500C, Battery charge: 100%, 12 minutes
