sayaka's avatar
sayaka
GS510TLP temperature
How can I get temperature on GS510TLP?
I checked some manual and this community.. but I can't find the pages.
Somebody please tell me this answer..
  • GS510TLP doesn't have a thermal sensor inside, so you cannot see its temprature
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi sayaka,
    Welcome to the community! :)
    I suggest you to install the NMS300.  The GS510TLP switch is compatible with the NMS300.  You can monitor temperature using NMS300.  Kindly read pages 102-107 of the NMS300 user manual here about Conifiguration Monitors.
    You can download the latest version of the NMS300 here.
    DaneA
    NETGEAR Community Team
    • sayaka's avatar
      sayaka
      Hi,DaneA
      Thank you for your reply.
      I just installed NMS300 and I can see interface traffic and so on.
      But I couldn't monitor temperature.
      I checked below setting was Enable.
      1.MONITOR>MONITOR CONFIGRATION>Device Temperature
      Sayaka
      • WilsonS's avatar
        WilsonS
        NETGEAR Expert
ProSupport for Business
