Dave40's avatar
Dave40
GS510TLP Port flapping
So had a similar issue with a GS108T where the ports would flap down then up repeatedly causing internet to break.  The GS510TLP has been updated to latest 6.6.2.9 firmware and RESET to DEFAULTS (which was the reason the GS108T port flapped.  Once the reset was done on that the issue went away).  Anyway, port flats, any port.
  • Since the bad cable was found I have not seen anymore port flapping.  Strange that it affected several ports
  • <13> Jun 24 11:51:10 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 826 %% Link Down: g5
    <15> Jun 24 11:51:10 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 825 %% HAPI LS callback, u 0. p 6
    <15> Jun 24 11:43:36 192.168.50.233-1 SNTP[SNTP]: sntp_client.c(1913) 824 %% SNTP: system clock synchronized on Sun Jun 24 11:43:36 2018 UTC. Indicates that SNTP has successfully synchronized the time of the box with the server (185.186.77.153).
    <15> Jun 24 11:42:31 192.168.50.233-1 SNTP[SNTP]: sntp_client.c(1913) 823 %% SNTP: system clock synchronized on Sun Jun 24 11:42:31 2018 UTC. Indicates that SNTP has successfully synchronized the time of the box with the server (185.186.77.153).
    <15> Jun 24 11:41:25 192.168.50.233-1 SNTP[SNTP]: sntp_client.c(1913) 822 %% SNTP: system clock synchronized on Sun Jun 24 11:41:25 2018 UTC. Indicates that SNTP has successfully synchronized the time of the box with the server (129.250.35.251).
    <15> Jun 24 11:40:19 192.168.50.233-1 SNTP[SNTP]: sntp_client.c(1913) 821 %% SNTP: system clock synchronized on Sun Jun 24 11:40:19 2018 UTC. Indicates that SNTP has successfully synchronized the time of the box with the server (95.215.175.2).
    <13> Jun 24 11:21:44 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 820 %% Link Up: g5
    <15> Jun 24 11:21:44 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 819 %% HAPI LS callback, u 0. p 6
    <13> Jun 24 11:21:40 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 818 %% Link Down: g5
    <15> Jun 24 11:21:40 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 817 %% HAPI LS callback, u 0. p 6
    <13> Jun 24 11:21:00 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 816 %% Link Up: g5
    <15> Jun 24 11:21:00 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 815 %% HAPI LS callback, u 0. p 6
    <13> Jun 24 11:20:56 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 814 %% Link Down: g5
    <15> Jun 24 11:20:56 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 813 %% HAPI LS callback, u 0. p 6
    <13> Jun 24 11:20:35 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 812 %% Link Up: g5
    <15> Jun 24 11:20:35 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 811 %% HAPI LS callback, u 0. p 6
    <13> Jun 24 11:19:40 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 810 %% Link Up: g4
    <15> Jun 24 11:19:40 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 809 %% HAPI LS callback, u 0. p 5
    <13> Jun 24 11:19:37 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 808 %% Link Down: g5
    <15> Jun 24 11:19:37 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 807 %% HAPI LS callback, u 0. p 6
    <13> Jun 24 11:19:35 192.168.50.233-1 TRAPMGR[trapTask]: traputil.c(721) 806 %% Link Up: g5
    <15> Jun 24 11:19:35 192.168.50.233-1 DRIVER[bcmLINK.0]: broad_link.c(83) 805 %% HAPI LS callback, u 0. p 6
    • Dave40's avatar
      Dave40
      Please tell me what those broadcom drivers errors mean - bad firmware?
      Why is SNTP going baserk?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Dave40,
    Kindly answer the questions below:
    a. Was the GS510TLP switch working fine before?
    b. Does all the ports flap even before you updated the firmware and factory reset the GS510TLP switch?
    c. How is everything connected?  It would be best if you post an image or screenshot of your detailed network setup.
    DaneA
    NETGEAR Community Team
    • Dave40's avatar
      Dave40
      a) So the switch is new and I had no issues prior to the switch install.  Was using a GS108T
      b) never tried the default factory firmware. It is still available on image2 and is 6.6.2.6.  On installation I updated the firmware and configured the settings.  I ran it for about a month and observed this port flapping and TCP connection failure issues across all devices - I've been too busy to fix. I will attempt to try the factory firmware after a few more days of testing.
      c) Internet Sky Q => GS108T (now swapped for an old FS105 dumb switch 100MB) => GS510TLP => Computer, WiFi, TV etc
      I've had everything disconnected apart from the FS105, Sky Q and the GS510TLP and WiFi and the problem is still there with this new switch - it was not there before I bought it.
      Yesterday, I disabled the SNTP (made it local time) and lo and behold the mental time checks (every few seconds and sporadically in bursts) have stopped (obviously, because it's now off) but also the port flapping appears much reduced and possibly cured.  I won't declare it solved yet as 1 days isn't suffient in my eyes.  So I'll monitor.  If I confirm SNTP issue then I'll report back - I'll also try the 6.6.2.6 to see if the problem exists there.
      Changes from DEFAULT config is that I disable STP, set SNTP to 0.uk.pool.ntp.org
      Have tried: IGMP OFF (think it was on but also had the problem before I turned that off), ARP renew is now OFF but had the issue before this was changed .
      I have just noticed that DNS is enabled but no DNS server entered.  I can't remember if I had this set before with SNTP.  I have factory reset a few times since.  Anyway, SNTP with no DNS server (but set to enabled) was the last known config that was causing this issue (with STP off also).
      • Dave40's avatar
        Dave40
        I must clarify the amount the SNTP I had in the logs = it was sincerily a lot of entries.  I was only able to supply a small snapshot due to the character limits on the forum.  It was sporadic but with entries of 10-20 every few seconds.  Polling was very high despite successfully updating time and resolving the DNS supplied. (probably without the DNS servers specified - really can't remember setting this)
ProSupport for Business
