silvercue
Aug 15, 2011Aspirant
ReadyNas Ultra 2 - Installation Problems
Hi - just setting up my ReadyNas Ultra 2. I have purchsed 2x3TB Hitachi disks that are on recomended products list. I understand I may have to upgrade the firmward to see the larger disks, but no...
silvercue
got password reset from security question. Had problems with volume size - after 3 factory resets now can see the drive so added a second and did factory reset....but the status light is yellow and although the disk lights show both disks as green Front View only sees one disk!!
I think it may be synching....but doesn' sayt that in the info. Will elave it for a while. Thought this would be easy.
