meridian180
Dec 14, 2020Aspirant
ReadyNAS Ultra 2 - Not discoverable with Raidar 6.4 via network or direct ethernet connection
Purchased a used (but in new/seemingly unused state) ReadyNAS Ultra 2 w/o drives. Installed an old drive (does the drive have to be "good"?), put in the power cords, ethernet cord to the router, ...
Sandshark
Dec 14, 2020Sensei
The NAS is discoverable via RAIDar without drives, but not by other processes. It uses a special broadcast method. The OS and all settings run from the drives, so it does not matter if somebody else set it up previously, that set-up was removed with the drive(s). For a NAS of that generation, you should use RAIDar 4.3.8, as it has a setup provision that is not in newer versions because newer NAS don't use it.
Yes, the drive has to work for the OS to be installed to it and run. And if the drive is used, there are some types of partitions that your older OS can't deal with, so you may need to remove them with a PC before the NAS can use the drive.
Your NAS can be converted to running the current OS6, but you lose Netgear support (including paid) if you do so. While OS6 updates are currently slow coming, OS4.2.x on your NAS has not been updated in about 3 years and will have no more updates.
meridian180
Dec 15, 2020Aspirant
Thanks for all the help!
What tripped me up was the Boot Menu "options". The initial Google search listing from netgear.com listed only holding the Reset button on Power Up. Despite being in pristine condition it must have been plugged in. (I do that, too. Where you don't undo the cords from their ties and try it out first.) So the IP addresses had been changed. It did need to be reset, but reseting is a bit more involved than just hitting the one Reset button. Sigh.
Well, I didn't give up and by RTFM a bit closer in another, later internet search, I learned that the "Backup" button on the front of the unit is involved in the reset process. Only it's called the Boot Menu. Not immediately obvious, even to a reasonably techy person like me? Menu implies seeing it on screen? Anyway... Once, I brought the Backup button to the party and selected the Factory Default option, then things got up and running, Raidar found the unit and even the old, crusty drives I had in there, and I was off to the races. The OS installed and everything was discoverable on the my network and all was well in the world. Well, my office.
So, lesson learned. I made the mistake of saying it was "used" to the Netgear support and the tech that 'helped' me rudely suggested I avoid buying used equipment, so I would avoid a broken network adapter. Except it wasn't a broken network adapter. If I hadn't mentioned it was used, would they have helped find this solution right away? If this person would have mentioned this Boot Menu via Backup button procedure right away, I'd have left the exchange a happy camper. Instead, I have a working unit by my own means (even if some of the intial fault was mine I admit!), but I'm no longer an interested future Netgear buyer.
But you two that responded have left good tips and info that are useful in their own right, so I appreciate that. Thank you for your time!!
.curt
ps. wanted to post the screenshot of the Boot Menu process but the file attachment button in my browser isn't cooperating...
- StephenBDec 16, 2020Guru - Experienced User
I made the mistake of saying it was "used" to the Netgear support and the tech that 'helped' me rudely suggested I avoid buying used equipment, so I would avoid a broken network adapter. Except it wasn't a broken network adapter. If I hadn't mentioned it was used, would they have helped find this solution right away?Netgear doesn't provide support on used equipment - it's actually surprising you were able to reach support. I guess it's possible that the previous owner never registered the NAS - if that's the case, Netgear would have no way to tell that your NAS was previously owned by someone else.
Here's a tip: googling Ultra 2 support should put the Netgear support page for your NAS at the top of the list. If it doesn't, you can just add site:netgear.com to the search string. That would have taken you more directly to the documentation for your NAS. https://www.netgear.com/support/product/RNDU2120%20Ultra%202.aspx#docs
The hardware manual describes the boot menu options (for your NAS, that is on pages 14-15). https://www.netgear.com/support/product/RNDU2120%20Ultra%202.aspx#docs
- meridian180Dec 16, 2020Aspirant
Hi StephenB,
Yeah, that's the weird part. I was upfront and clear in my initial contact that it was purchased "second hand". I did offer the serial number to check the registration status. I even offered to send it in, on my own dime for repairs. At that point, they then just responded it was EOL and there wasn't anything they could do for me. He stated it was literally my fault for buying a "used" item with a bad network adapter. Other companies, tech and non-tech have done simple, quick troubleshooting steps to help people. It just builds good will. if I could post the screenshot of the email response I would (safari isn't playing nice). They went the other direction. They were passive aggresively rude.
And the nominclature of Resetting vs Boot Menu is what got me. Is was the reading a thread about someone unit losing connection after a router change or something like that. Finding info about Resetting via the Boot Menu wasn't where I expected it, even if it was in the manual. The blame for that is going to be mostly on me, of course. And I can see an engineer thinking it's a "cute" solution. But it's unconventional for a Factory Reset, in my experience.But anyway, thanks again for the help. And the info on this thread for posterity. Hopefully it helps others in the future, too.
Cheers,
.curt
ps. I edited the post in Firefox and added the screenshot of the email response. It might seem tame, but it comes off passive aggressive to me. Especially when it had not been determined that the adapter was indeed faulty or not. They took the time to send that instead of just saying "search the manual for boot menu" and be done with it. [insearch shrug here]
