asonswe
May 16, 2017Aspirant
ReadyNas Ultra 2, firmware 4.2.30, suddenly starts to create snap-shots.
Have run my ReadyNas for several years. A couple of months ago it (without my action) created snap-shots of the shares. I have in vain tried several methods to delete them. I communicate with...
- May 19, 2017
I spent a lot of time tying to correct the system and I am now fed up with it.
It's time for the sledge hammer!;
1. Copy all files, 1 TB data, to an external drive.
2. Factory reset the ReadyNas including flashing the OS from the internal memory.
3. Re-write the hard drives with zeros and re-format.
4. Completely new set up of the ReadyNas.
5. Copy all files back to origin place.
Finished and ready to go! Problem solved. Case closed!
mdgm-ntgr
May 17, 2017NETGEAR Employee Retired
Perhaps run the Online Filesystem Consistency check again and see if that clears it up.
- asonsweMay 17, 2017Aspirant
Thanks for your advice.
I run the "Disk cleaning with automatic parity correction" and the "Online Filesystem Consistency check" directly I found a normal delete did not function.
To be absolutely sure I run the "Online Filesystem Consistency check" once more, just before writing this. Unfortunately no cure.....
- asonsweMay 19, 2017Aspirant
