nasmk
Mar 03, 2013Aspirant
Readynas Ultra 2 not possible to create a iSCSI target
Hi all, I m new in the iSCSI target but wanna try it for small business. When I wanna create a iSCSI target disk its not possible ... why ? i dont know... Do I need blank disks to do that? ore...
mangrove
Mar 15, 2013Apprentice
Ghosthack wrote: iSCSI is fastest access to the ReadyNAS on Ultra and Pro my experience (Much faster and have possible to loadbalance if use two NICs)... Where do you get the 25-30% slower (Have you tested)? That Netgear using file instead of volume to iSCSI is because its easer to implement, but volume is generally faster.
Then you most likely have some network related problems with your SMB setup. Of course I have tested, and also, here are the official performance numbers:
http://www.readynas.com/?page_id=5410
